Hi All, any suggestions on how to deal with this floor cavity?
Previously there were some patio doors here which brought up moisture through capillary action via the screws securing the doors to the brick course. Since the removal of these doors there has been no issues with damp/moisture. It’s been dried out for a while now.
How do I cover this section to then lay my flooring? The dpm taped over the flooring isn’t the original and looks to be placed under the flooring underlay. Can I just simple use some self levelling compound. The original slab has some foam insulation between the slab and brick course, it also sits slightly lower by 5-10mm. The new slab has dpm edges butted up against the bricks.
