What sort of LED is this?,I'm wanting to run a 5v led on a 7.5v supply,what value resistor do i need?
Each colour has a diffrent voltage red around 1.2 volt so 7.5-1.2=6.3/current rating say 30 mA = 210 ohm. Replace with real values to get real size.
I've not found it to be the problem others have warned about.Assuming your supply is DC not AC.
If you have an AC supply it would be best to consider one of these options:-
A/ run a second similar LED and resistor as an inverse to the first one.
B/ place a diode in reverse across the LED (say 1N4001 to 4 for example).
An LED run not to exceed its max current (including running it well below its max current) and protecting against reverse voltage can be expected to live long.
I fitted some dummy bell boxes to my house but added red LEDs to make them look like the proper thing. I used the mains transformer from a scrap cassette recorder - so about 6V or so and in the bell boxes a simple series resistor and 3mm red led superglued in a hole. I happened to drive past last week while visiting a friend in hospital and see there is still life, I sold and moved in 1993. Judging by the appearence of the house I suspect they would not have bothered with a repair.Indeed, 30 to 40 years ago I ran some burglar alarm bellboxes with tell tale LED on the front cover and they still going strong today.
As a potential divider it would have that effect, however from memmory I think it was something in the order of 1.5kΩ series and 5KΩ shunt so I don't know to what extent it would protect the LED.I presume the reason for a pair of resistors rather than just a series resistor is to limit the reverse voltage.
Yes Harry with two back to back for AC one series resistor to them is ok for both and indeed if you using one LED and a reverse diode then again you one resistor would be ok too.A diode would be simpler, or two LED's back to back plus a single series resistor.
