Longtime lurker here with my first post.
We are converting and extending a garage to form a dwelling, we are only retaining the footings and ground floor slab of the garage.
My interpretation of the building regulations is that:
5. For the purposes of paragraph 8(1)(e) of Schedule 1 to the Act and for the purposes of these
Regulations, there is a material change of use where there is a change in the purposes for which or
the circumstances in which a building is used, so that after that change—
(a) the building is used as a dwelling, where previously it was not;
I know of no legislation or regulations that specify how much of the original building/structure must be retained.
Building control have advised that they are treating it as a new build because I have reduced the original structure to slab level and as such I have to comply with new build regulations and all that that entails.
Are they correct? Is there some legislation that I am unaware of?
What makes this all the more frustrating is that I checked verbally over the phone how they would treat the application ie new build or material change of use before I did the design to be told by them it was material change of use.
It took them 8 weeks after I deposited the plans to advise me and we had already started on site and are up the slab level.
I have written and complained stating my case but they are unmoved so now I've had to close site while I sort the SAP calculations and see if I can make it work as a new build (I have a lot of glass in the design) within my budget.
I'd appreciate some views if anyone out there understands how to interpret the building regs correctly.
