Code 2 Would benefit from improvement but not dangerous. Satisfactory classification
May or may not be satisfactory (inspector's judgement required) I believe would be more appropriate.
My definitions are trying to position it so that if it requires improvement to the extent it would cause an unsatisfactory classification it should actually be thought of as dangerous and therefore a code 1
I thought I had already conceded that in your particular scenario it would achieve little.
The problem with the Regulations is that if we accept that they are concerned primarily with safety, then it is difficult to argue that a non-compliance does not at least require improvement.
All the time we see electricians here who can barely string two words together and remain coherent.I feel most electricians will know how to inspect and test and how to write a technical report on what they have found.
But those people are wrong.In some cases near opposite meanings as with "Decimate" which comes from the Latin and days of Roman's meaning to kill one in ten. Hence "Deci" meaning ten. However many now consider it to mean to get rid of nearly everything.
Unless you go with the (utterly and disgustingly appalling) decision of the Oxford dictionary, of all institutions, to dumb themselves down to the level of the semi-literate idiots who think that "electrocution" means a non-fatal electric shock.Words like "need" and "dangerous" seem to mean different things to different people and really they need qualifying i.e. "Danger of electrocution" which of course is very different to "Danger of getting a shock".
And there's another oft-misunderstood word. How many people, when told that their performance or creations were "satisfactory" feel that they have been criticised? (As an aside, "adequate" is another such word).And so if the item is safe unless there is some one armed with tools I would say it's satisfactory.
But "satisfactory" is subjective.Code 2 Would benefit from improvement but not dangerous. Satisfactory classification
The only problem then is it becomes subjective again. My definitions are trying to position it so that if it requires improvement to the extent it would cause an unsatisfactory classification it should actually be thought of as dangerous and therefore a code 1
So if you consider it unacceptable for the installation to contain a spur to a boiler not wired in brown/blue, how would you code it?Indeed. But I said that in your specific scenario it would likely achieve little to alter it. I also stated that this did not mean that such an installation method was acceptable.
How can unidentified switch live conductors, if left, give rise to danger though? Personally I'd go with a code 4.
So how should an old, but perfectly sound and leak-free gas cooker without an FSD, in a flat, be judged?Is the Gas system any clearer?
- Immediate Danger (disconnection or making safe required)
- At Risk
- Not Current Standards
Yes, but you seem to be ignoring the fact that you also said "The problem with the Regulations is that if we accept that they are concerned primarily with safety, then it is difficult to argue that a non-compliance does not at least require improvement."I have already acknowledged on several occasions that I would not require this particular scenario to introduce a danger.
They all are, and what's worse an opinion which ought to be, but cannot be, informed by other factors....It's a matter of opinion.
But what danger is there in that?How can unidentified switch live conductors, if left, give rise to danger though? Personally I'd go with a code 4.
If someone does not identify it as a line conductor, which is the reason why they require identification.
Could be. Might not be. Might not be depending on who is doing what with/to the installation....?My point is that if the Regulations are concerned with safety, then it surely follows that non-compliances could be less safe.
Maybe there is absolutely no point to having a Code 4? How many installations over 2 years old would you now find with no Code 4's, even if originally done 100% perfectly and never fiddled with since?This is where the difference between Codes 2 and 4 can become blurred.
Code 1. Dangerous Leading to a unsatisfactory classification.
Code 3. Needs further investigation.
