I've double coated my walls and plan to fit the architrave and skirting next.
Do I paint the skirting, architraves and then caulk or should it be done in a different order?
Fill any large gaps in skirting.
Undercoat then caulk.
When you're happy no more filling or another caulk is required, second undercoat over the caulk.
Caulk likes a sealed surface so on wood and bare plaster it's not always the best surface to caulk. Some do and it fine however, best to undercoat then caulk.
