When were mains (230V/240V) underwater lights banned?
28 Jul 2012
Surrey
I know some very old water fountains use to have mains powered underwater lights. Just wondering what the history is behind when the were banned and made presumably illegal?
Regards: Elliott.
We have a mains-powered submerged pond pump. I'm sure they aren't banned... or I hope not.
Why should mains-powered underwater lamps be banned, assuming they have the same waterproofing applied?
Mains pond pumps are allowed, but I am sure back in the 50's/60's/70's there used to be 240v underwater lights feed straight from the mains used in ponds and commercial fountains. I was under the impression that these are no longer allowed and I wanted to know when did this change and under what regulation?
It would seem if they comply with BS EN 60598 then allowed under BS7671:2008 not got either BS EN 60598 or BS7671:2018 so maybe changed. But you need to be able to service from behind the unit, so limited where they can be used.
Memories from child hood.
You would be at a restraunt with a pond and there would be a couple or brightly coloured spot lamps under water.
Typically one or more would be blown, leaving just one :(
Regards: Elliott.
Never.
