Where can I buy melamine/laminate sheet ?
11 Jan 2004
Hello
Can anyone suggest where I can buy a small sheet approx 5ft x 2ft sheet of melamine sheet to make a surface waterproof. I think it is basically the same stuff that a kitchen counter/ worktop is surfaced with.
Normally you buy melamine already on a sheet of plywood, MDF etc. Might we ask what it is you want to do?
B&Q sell melamine covered wood.
600mm wide.
With or without full edging and in some stores you can get it cut down to your required size for free.
You can also try asking in your local woodyards, I know mine (Ashworths in Rossendale) used to do it but I have not been there for years.
Waterproof or splash proof?
Would a solid plastic not be suitable?
We used to buy faced ply and buffalo board.
Buffalo is used in truck and trailer bases.
You still need to worry about edges.
It isn't waterproof - are you perhaps thinking of Formica-faced board?
A few years ago I was in a DIY store where I heard two 'builders' pulling out some white 225 x 8ft contiboard and one saying to the other, "this will do for the fascia board".
We used to get ours from Llandaff Laminates in Cardiff. I suspect there are similar dealers all over.
google HPL sheets and you'll find loads of suppliers
Thanks everyone for your feedback. I think It meant laminate sheet not melamine sheet .
Cheers
