Where can I get these ??
28 Jul 2006
Oxfordshire
I've seen them from time to time and now I have one in captivity! Never seen them in wholesalers etc.......
Its a clamp/link that allows you to connect two metal back boxes together. In this picture there's a double box connected to a single (eg for a fused spur in a kitchen.)
I know that you can get ready made 2Gang + 1gang boxes (from Deta etc) but i'm particularly interested in these gizmos......
Any idea where they can be bought??
Thanks Spark. And I though I knew the TLC catalogue backwards - stoopid Taylor :oops:
and
would this item solve the problem of getting two boxes right next to each other perfectly level ?
exactly the reason for the query....
Does the centre bit remain proud ?
If so then the boxes will have to be set deeper, or do you take it off after the plasterers has been round ?
Yes but beware when your customer decides half way though the job that they want flat plate accessories. Aside from the boxes being only just deep enough -the flat plates overlap! GRRR
Yes, I've been caught out on that with the dual boxes.
TLC state these only good for standard white plastic accessories.
Dexion.
A bit more work, but makes sure the boxes are level, and you can space them as far apart as you like.
I've never thought to compare - do all boxes have the KOs in the same places, even if of different makes?
Think they can vary in distance between the knockouts on the sides and the top/bottom on the single boxes, if you have two of the same make which you probably will have if doing an installation job then it shouldn't be a problem.
