    Dismiss Notice
where to find: fitting for 2D 20W 2pin lamp
Discussion in 'Electrics UK' started by tim00, 17 Oct 2011.
  1. tim00
    tim00
    30 Jun 2004
    661
    Thanks Received:
    57
    Country:
    Where would i source a fitting for a 2D 20W 2 pin lamp? I presume it's a batten type fitting? Tlc dont seem to list one.
  2. Sponsored Links
  3. RF Lighting
    RF Lighting
    31 Mar 2006
    19,993
    Thanks Received:
    1,354
    Leeds
    Country:
    Are you sure it's 20W?
    2D's normally come in 16W, 28W, 38W, 50W
  4. 333rocky333
    333rocky333
    12 Jan 2008
    8,272
    Thanks Received:
    874
    Essex
    Country:
    A batten fitting uses a linear tube anything up to 8 foot long,
    2D lamps go usually in sguare or round enclosed fittings.
    A 21 watt 2D lamp exists but quite rare and usually high frequency control gear and therefore 4 pin
  5. securespark
    securespark
    11 Jan 2004
    36,543
    Thanks Received:
    1,239
    Country:
    isn't there a reduced-wattage version of the 28W?
    A bit like there's a reduced wattage version of the 500W linear floodlamps.
  6. 333rocky333
    333rocky333
    12 Jan 2008
    8,272
    Thanks Received:
    874
    Essex
    Country:
  7. tim00
    tim00
    30 Jun 2004
    661
    Thanks Received:
    57
    Country:
    You guys were quite right, it's a 28W, my mistake. And the circular, enclosed fitting is the correct term not a batten ( no matter iv'e always called them battens, i guess that i've always been wrong with my terminology ).
    I think that i'll pull the in-situ enclosed fitting, ( a dim 16W, too small to take the 28W,) and fit a rose. Thanks for your replies.
  8. 333rocky333
    333rocky333
    12 Jan 2008
    8,272
    Thanks Received:
    874
    Essex
    Country:
    It would not have been wise to fit a 28 watt lamp in a 16 watt fitting anyway as the control gear is different.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
