Hi looking for a basic white double socket, any to avoid ?
Thanks that’s all I needed, it’s only for a bedroom cupboardLots...
But also lots of good ones available ie
MK DP Switched Socket 2 Gang | Toolstation
A simple but stylish double socket featuring soft, rounded edges and a slim profile - it's a practical, reliable and cost-effective option to suit any home interior.Terminals are grouped inline with backed out screws ready for quick wiring. Clear markings on the dark background makes them easily...www.toolstation.com
https://www.toolstation.com/click-mode-dp-switched-socket/p77115 my current! favourite
Crabtree Switched Socket
The Crabtree switched socket is ideal to update a home for a more modern look. This switched socket is white in colour and will fit into any type of decor or wall colour in any room of the house, with a solid profile that features a slightly bevelled edge. With this socket, you will get the...www.toolstation.com
I actually agree about LAP. When I hear people saying we should avoid LAP I always find myself wanting to ask “What’s wrong with LAP?”I have used LAP a lot, as yet not found a fault with them. Any socket can go faulty, but with a standard 13 amp socket can't really see how any one is better than another? OK with USB, RCD, SPD included there may be good and bad, but as standard 13 amp not really a problem one make to another.
Nothing that I've discovered yetI actually agree about LAP. When I hear people saying we should avoid LAP I always find myself wanting to ask “What’s wrong with LAP?”
Now I've heard lots of such comments and the few (and it is only a few) BG accessories I've used have been OK apart from the bathroom pull switch which seem to have a life span of 2 months... I won't mention the 20A DP switch on 10.5KW shower but then it was put in by a tenant to replace the MK 45/50A version when it failed.Avoid BG.
Avoid any big shed own brands and LAP
and axiom
One often sees comments like these. The fact that there are usually almost as many (different) "avoid XYZ" opinions voiced as there are people offering opinions (usually with, as here, others saying that they have had no problems with XYZ) seems to suggest that, in general, there is actually very little to choose between them.,Avoid BG.
Avoid BG.
