Which Draught Excluder seal would you go for?
22 Aug 2018
This might sound like a ridiculous question, but whats the difference between the different seals?
I went to B&Q this afternoon and theres foam, rubber, brush and then theres P, E, I shapes.
How is this DIY job such a minefield :LOL:
I would choose the one that fits my door. But this won’t help you if you have a different door.
Some more background information would be really helpful.
Its basically just a solid wood front door with about 5mm gap around the door. What other info would you need?
Does it have a channel in the frame to take one of the P, E or I types of seal?
You need to know the height of the gap you are trying to seal and then the width of the channel to locate the seal.
You can then simply select the right type to suit.
If you don’t have a channel you are most likely looking at a foam seal you can stick around the frame.
I hope this is some help but yes it is a ridiculous question as it should be self explanatory:)
Yeah theres a channel all around the frame but its only notched out the wood, its not like how you'd find a channel on upvc where the seal pushes into it.
Excuse me for being naive, but what difference does the height of the gap make apart from how much i'd need to cut, I understand this to be the internal height of the frame?
The width of the channel is 5mm.
