Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Could you (slowly & carefully, as you'd have to omit the pilot drill) cut round the screws with a small holesaw so you can then prise away a lot of the wood holding the screws in, then they might come out a lot easier? Use a size which matches dowel you have or can buy and making good won't be too hard.
Thanks all. I tried mole grips. I tried pliers. Both just chewed up the thread without rotating the screws. I ended up getting a bosch metalmax blade, cutting them flush, then using a dremel tool with grinding wheel to bring the top of the screws just under the wood. Ronseal wood filler. Sanded. Just painted it now.
I did debate doing this. I think my issue was that the screws were 80mm long, and around 25mm had snapped off. So still had 55mm to try to drill around. I decided it was quicker and easier to cut the screws flush and just fill.
80mm would be reasonable for fixing a 10mm bar through a 25mm batten, for example. The rough rule of thumb is to have a a screw 3x the thickness of the item being fixed; use a 36mm screw to fix a 12.5mm plasterboard etc
my wife wanted a pressure fit stair gate. We didn’t have a suitable Jewell post (it’s round where the upper pressure fitting would go. I was worried about how secure the batten would be. By the time my son could walk, he would hang off the stair gate and try and pull it down! I’m glad I went OTT from a safety perspective.
