Hi all
I am adding some Texecom Exodus sensors to my panel. Mostly these will be the OH optical and heat models which look like the best for most domestic rooms. I also want to add some to my kitchen, boiler/plant room, garage, un-boarded loft with blown insulation, a toolshed/workshop and a barn above where we keep mini tractors and some hay.
I was going to go rate of rise for these but I'm now second guessing this decision.
I think that for kitchen maybe the FT64 would be better?
I know loft temperatures can vary but would the rate of rise be quick enough to trigger the rr detector?
Same as above for garage
Plant room is always warm, but usually below the 38 mentioned on the rr spec, or am I asking for trouble here and better going FT64.How important is it that is stays below 38 when it shouldn't trigger unless fast rate of rise or exceeding 58?
Any thoughts about the toolshed/workshop or the tractor/hay barn I need to consider.
As I said - I thought the speed of temp rise to trigger the rr sensor would mean it was safe in these locations but now I'm not sure - and given the internal and external sounders that will all get triggered with false alarms and having a 2 year old in the house the wife would NOT be impressed if we start getting false alarms in the night requiring panicked explorations of the loft and outbuildings. - Yes of course we would all be grateful if it protected us from an actual fire but I am focussing on preventing false alarms right now.
Thanks in advance.
Thanks in advance.
