Hope it's 760mm away from that wooden fence...also why is the pipe slung across the path like that? That wants moving and clipping to the wall. I'd have put a proper isolator-first valve on the tank as well, the one they've fitted is really vulnerable to damage
Haven't measured it - I suppose at the end of the day I (who know nothing about these things) just have to trust somebody. They're a long-established, apparently reputable firm, OFTEC etc.
Maybe it's a bad photo? There isn't a pipe on the path, unless you mean the yellow hose I was using? The tank output is in a corner between the tank and a wall, so hopefully unlikely to get damaged...
*edit - sorry, see what you mean now. It's just the picture I think - the path is to the right of that gravelled area, and the pipe goes down into the ground just immediately out of shot. Then there's a little inspection hatch which you can't see.
