whirlpool ADG 7540 DISHWASHER
2 Oct 2010
Derbyshire
Hi, Intergrated unit, COULD ANYONE TELL ME IF THERE ARE ANY ADJUSTMENTS ON THE DOOR AND WHAT SIZE STAR DRIVER DO I NEED, the reason for this is the door will not open fully as the bottom of the door hits the dishwasher base, and the unit door is fitted correctly,
18 May 2008
Cornwall
I am assuming you mean the door outer trim is hitting the kick strip at the bottom when you go to open the door. A pic could help.
There is no adjustment for the actual door of the machine, the outer trim is fitted to match your cabinets either side, typically it will be slightly shorter than those either side or a piece of the kick strip underneath the machine is cut out along the top edge so that they do not foul on each other.
2 Oct 2010
Derbyshire
i realise this is difficult to put over, the cabinet door fitted to the dishwasher hits the bottom frame of the dishwasher not the kick board, its as if the unit door is to low on the washer door its fitted to, but this is not the case,,,,,,,
18 May 2008
Cornwall
There is no other way to get round it if the top of the outer trim is in line with the top of your cabinets
