My machine completes washing cycle and rinses. Partially drains but then stops at spin and just whirrs, but no drum movement. I've cleaned and checked filter. Looks ok. Any suggestions?
Could be motor brushes are about to expire, if it drains then pump is ok.You could manually drain by lowerng the outlet hose into a bowl and see if it finishes cycle.
