Might sound stupid to the Pro's, but i've just had a look at the kitchen sink I want to move and i've noticed green and yellow wires attached to the hot and cold pipes underneath the sink. Closer inspection revealed a metal tag which says "Electrical Safety Connections DO NOT REMOVE"
Emptying the tank and disconnecting the waste is obviously no problem, but theses wires are new to me. They are attached to the main pipes and NOT the actual taps, so can I go ahead and unscrew the taps and remove the sink without worrying about getting electricuted?
What are the wires for anyway? I'll need to know either way because the hot and cold pipes the wires are attacthed to need to be extended so I can get water to the sinks new location. All words of wisdom will be gratefully received.
Sincerley Yours
Wet behind the Ears...
Sincerley Yours
