- Joined
- 27 Jan 2008
- Messages
- 29,866
- Reaction score
- 3,718
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Not sure which is best, likely no zone valves and TRV heads which can be programmed work better. The problem is how to stop the boiler cycling as warmer weather arrives, traditional method was manually turn it off, or fit a thermostat in the room kept coolest with no alternative heating and no outside doors.Isn't that a good enough reason
bear in mind that some plumbers are only now fitting zone valves and room stats because the regs say they have to. I suspect many would be happy to fit on-TRV valves and no controls if they could.
However when the thermostat started to be fitted with either anti-hysteresis software or connected to the ebus the whole idea was turned on it's head, today it seems we have three systems, EvoHome and Tado use OpenTherm and the TRV head tells the thermostat how much heat is required, Nest also uses OpenTherm but simply uses a follow command so TRV's change temperature with the wall thermostat, and Hive uses off/on (mark/space) with a "heat on demand" function so if any TRV wants heat the boiler runs, using the return water temperature to modulate the boiler.
Oil boilers often don't modulate anyway so zone valves still work, but with gas fitting zone valves defeats the boiler modulating, so it does seem plumbers are right, better not having zone valves, except with oil, the government has just not caught up with changes. Or those saying must have zone valves are misreading the regulations?
But is seems we are all no longer allowed to be tradesmen, the whole idea of using our brain and working out what is appropriate has gone, we all have to blindly follow rules, like with mothers house they wanted to fit windows that would let inferred heat in but not out, but the problem was the rooms got too hot in the sun light, south facing windows needed to be opposite way around to stop inferred coming into the house.
