As I said, I very much doubt it (and probably even more so in the case of paracetamol), at least as non-prescription medicines.Our Generation were brought up on Aspirins. Would they be allowed today?
Yep, the same with them.
Because of changing attitudes over time. If alcohol or tobacco were first to appear today, there is not a chance in hell that they would be 'accepted', and would be regarded, treated and legislated for in just the same way as heroin, cocaine, MDMA and whatever.
In all of the cases, effectively changing things retrospectively ('turning the clock back') would be next-to-impossible.
Or alcohol?
Because the Government is making a forking mint out of it.
Quite so - hence the only way of minimising (but not eliminating) the risk of members of the general public obtaining a potentially lethal number of tablets would be to completely ban them or, at least, make them prescription-only.It used to cost 99p for a bottle of a hundred not long since, until they decided to thwart those who might choose to deliberately overdose. There`s me at the supermarket buying several packets at a time of paracetamol/aspirin by going thru each different checkout until one of them realises and gets pedantic so I go out of the entrance then walk back in and go thru the ritual again, when challenged I tell them each checkout is and Moreso each in and out the entrance door is actually a separate transaction. .... Those determined enough never think to go to several smaller shops in a town centre and just buy the allowance once each do they?
I suppose that, in terms of current thinking, that would make some sense - but it would be much more difficult to do anything about established food items which naturally came with very high levels of salt, so people might start using them in lieu of 'salt' out of a jar or packet (unless one somehow 'banned' those food items as well!).I think I heard once that if salt were discovered today there would be no chance of it being allowed as a food additive.
Indeed - but not only as 'remedies'. One tends to forget that the 'proscribing'/banning of substances was essentially a post-war (WWII) phenomenon. Prior to that, there were plenty of things (like various opium derivatives) that were freely and legally available, and used in essentially what we would call a 'recreational' manner today.But interesting that you mention those drugs, because .... In the case of the 3 you list, all were proscribed many years after their invention, despite in some cases having been popular over-the-counter remedies manufactured by mainstream pharmaceutical companies.
Indeed- but, as I implied, Nanny has to decide 'where to stop' - given that there are very-widely-consumed 'borderline' substances like tea, coffee, chocolate etc.I think in fact that until relatively recently, when they changed the law to basically make "anything which gets you high" a controlled substance, to stop the continual chasing after new synthetics, all recreational drugs were made "illegal" after they'd come to be used recreationally.
Horses for courses. I personally generally find paracetamol to be more effective than anti-inflammatory drugs like aspirin and ibuprofen but others, probably like you, experience the opposite.I've never found paracetamol on its own to be particularly therapeutic in the first place.
But that is basically replacing the existing road fund license, not the selection of taxes and duties on oil based fuels.They have indeed found a way....EVs will soon be taxed at a rate higher than the current zero rate. Anything up to £190 for EVs and hybrids within a couple of years.
Ibuprofen also contains paracetamol and the pack warns not to mix with other paracetamol based drugs.Horses for courses. I personally generally find paracetamol to be more effective than anti-inflammatory drugs like aspirin and ibuprofen but others, probably like you, experience the opposite.
One of the problems with all of these things is delayed onset and limited duration of action - typically taking 30 mins or more to start working and then having peak effect for only a couple of hours, but with instructions that they should not be taken more frequently than 4-hourly. However, since paracetamol and the anti-inflammatories are chemically and pharmacologically totally different, one can take both, simultaneously if one wishes but, better, staggered - if one takes 'something' every two hours, alternating paracetamol and aspirin/ibuprofen, one then gets pretty 'constant' therapeutic effect.
Rubbish. Ibuprofen is ibuprofen and paracetamol is paracetamol. However ....Ibuprofen also contains paracetamol
... there are some products around which contain both paracetamol and ibuprofen, and they understandably come with such a warning. However, they generally only contain a 'half dose' of paracetamol (and sometimes a fairly low dose of ibuprofen), so they are in some senses pretty useless!and the pack warns not to mix with other paracetamol based drugs.
Well I've just looked at a pack of Sainsburys Ibuprofen and no paracetamol in them.Ibuprofen also contains paracetamol and the pack warns not to mix with other paracetamol based drugs.
Something sold as "ibuprofen" cannot, and must not, include any active ingredient other than ibuprofen.Well I've just looked at a pack of Sainsburys Ibuprofen and no paracetamol in them.
It's not a matter of brand, it's a question of "what it is". As I said, combination products (containing both ibuprofen and paracetamol do exist (now, I don't know about 2000). There is no official name for the combination, so is sold under the manufacturer's proprietary name (e.g. Nuramol or Combogesic), but must not be sold as "ibuprofen".When I had knee troubles around 2000 the tabs I was getting did, makes me wonder if ingredients have changed or specific to the brand I was getting.
Nuromol is one of the combination products. It contains a 'full standard dose' of ibuprofen (200 mg), but only a 'half dose' of paracetamol (500mg, the usual adult dose being 1,000mg)Seems that Nuromol is a full strength example: Ibuprofen 200mg and paracetamol 500mg.
