Other than bad workmanship the problem is copper creep which is aggravated by heating and cooling cycles. Like you I've not knowingly encountered a properly installed JB failure. Sure I have where it is apparent that it was not properly installed and on a regular enough basis to wonder if it was an issue with the JB or the concept.I have known very many properties that have had countless 'brown JBs' under the floorboards, and can't recall having personally ever been aware of any of them resulting in any problems - so I do have to wonder how common the perceived 'problem' actually is. Indeed, even if they are not particularly 'well made' or particularly 'substantial', I'm not sure that they would be likely to result in problems when left undisturbed under floorboards for a few decades!
Two of the bugbears I have:
The lack of thread length making the terminal tricky to load without the screw falling out which could result in a poorly completed termination as multiple wires and fiddly screw are wrestled into position,
Another being the ease of crossthreading the screw which commonly spreads the terminal slot open, causing a poor joint and cracking the Bakelite (sp?) -
I'd put those down to bad installation with an element of less than ideal design.
