My comment was solely in response to your mention of MF joints and that is only relevant when there are 'joints' (through which current flows, or may/could flow).
However, contrary to what I was previously thinking, secure seems to now be saying that there was a joint between two cables - in which case, at the least, the joint would have to be MF.
Are you related to bernard?
The same can be said (as bernard often does say), of any electrical accessory mounted on a potentially damp wall. One can't deny the theoretical possibility you mention but the chances of it ever doing appreciable harm in practice must surely be vanishingly small - even more so behind glazed tiles than in one of bernard's damp walls.
In any event, as I said, my comments were about the requirement (or not) for 'MF' terminations/joints - and MF JBs are not required to offer (and do not offer) any protection against water or moisture!
