Wind noise
30 Jun 2005
I had UPVC replacement windows fitted 12months ago and recently because it’s windy there is a what can only be described as a “flute” noise coming from our bedroom window when the wind gusts. I’ve read elsewhere this could be a sealant issue? Any advice is appreciated
Had it myself turned out to be a tiny crack in the mastic around the top of the window, resealed and now fine.
Cheers footprints. Hope mine is just as simple coz it’s driving me up the wall!
Its when the silicone has been fingered and pushed into the small gaps and its turned wafer thin and now dried, any gaps in the outer silicone or even wind blowing through the cavity vibrates the wafer thin silicone like a reed hence the noise, you can sometime generate the noise by opening and closing the door sharply, the pressure increase and vacuum will cause the same
So will the damage to the silicone definitely be on the outside coz I plan to have a look tomorrow? Also, if I find any damage do I remove it and replace or silicone over?
Outside most likely but check inside too, the draught from a cavity wall can bypass the outer seal.
It's the internal silicone that's vibrating but it's the wind/air flow that's causing it, check outside for any shrunken silicone and pull off and redo certainly but you could still get wind through air bricks. If you have plastic trims internally it'll be more the silicone applied between the frame and trims rather than window to plaster/wallpaper
Ok thanks for all your advice. I’ve inspected the inside trim that had a bit of movement on it. I’ve removed the silicone and re sealed it. That’s stopped 80% of the noise but I think the remainder of the noise is coming from where the window closes onto the foam seal on the hinge side of the opening. Can I adjust this? Or replace?
