The irony is that BMW is using dirty coal
Germany abandoned nuke a while ago. Reason the greens and popular support. The greens in power had to face up to real problems. They appear to have decided that CO2 is preferable to nuke. They can't get away with ignoring that the power is needed. Ok greens have been around but progress on wind for instance appears to be similar to ours. Facts to remember if people here start voting green. Things can only change at a certain rate. Merkel has mixed feelings about gas usage - wouldn't surprise me if nuke fitted in with that.
It seems several German nuke stations are due to close around now. That is being questioned but political and public views vary. Some are saying more nuke but as with us their nuke industry has been run down but somewhat more recently.
Germany has been importing Russian coal. Likely to be better quality than their own brown stuff. They could get it If from elsewhere. Their use of their own brown stuff may have ended yonks ago - pass. It and actually us were responsible for destroying Nordic forests. The first move was better coal.
China. I did find a report on power. 50% of their primary source is coal. They have a plan and use is reducing. From memory zero use is 2050. Some is used for heating as it has been here and still is to a limited extent. It seems they have banned use where pollution gets too high. Some gets turned to coal gas. The country covers an enormous area so clearly they have a bit of a problem doing the lot at once. China can produce "good" coal. If they produce gas from it they will also produce coke.
My dad would never use it as like many thought the goodness was taken out. Not enough heat. He was an intelligent bloke. A friends parents always used it as cheaper and it did produce plenty of heat. Maybe more was needed, pass.
Coking coal, also known as metallurgical coal, is used exclusively as an essential ingredient for steel production. The coal is 'baked' in a coke oven which forces out impurities to produce coke, which is a form of almost pure carbon.
It probably does burn cleaner. Furnace nuts were used for steel in the past. Small pieces of a certain grade of coal that can burn near white hot.
Then BMW going there. There is no saying what primary power source they will be using to run. Steel probably little different to elsewhere. China has a growing nuke industry. Some indication that they have been working on more advanced stations.
Sounds like Japan is going back into nuke. Each time there is a disaster all get updated. Not sure where Japan's problem fits in with that.
Station life is likely to be 80years. France has been extending life. No idea what that involved.
