Window Furniture
4 Aug 2004
I have a latch and window fastener on a small window both of which were originally coated in a brown semi-transparent metal coating. Now this is peeling off and it doesn't look good. I'd like to simply both the items. But, try as I might, I cannot undo the screws on the fastener. They are simply too tight. Any suggestions?
:idea:
assuming they are slot screws
take the correct size screwdriver firmly tap the driver into the screwhead and try to tighten 1/4 turnfirst before loosening
use a pair off pliers pipe grips or spanner as applicably for extra leverage
if its a phillips or pozi
sellect the correct driver/bit [probably a pz2/pro2] and as above
