I am currently refitting the bathroom, part of which involves exterior dranage so I have a scaffold up. The roughcast above the window was in very poor condition so I have removed some of it to examine the lintel. To my horror I found that there was considerable wastage and a lot of loose material that doesn't look like concrete at all. In addition a 1/4" steel plate abut 3" deep is located at window head height to provide additional support for what is I suspect a bodged repair done some years ago by the looks of it. The interior of the lintel has some severe looking cracks to add to the mix.
The existing lintel was I think cast in situ, on a 9" solid wall, and is 1250mm wide by 320mm high with a window opening of 800mm. The plan is to acrow the 3 roof joists that are supported by the lintel using a spreader beam across the floor joists, remove the existing, insert a new precast lintel with brickwork filling in above to the wall plate. If the wall plate shows any signs of rot it can be dealt with at the same time. I was thinking that a lintel 1200 by 215 deep by 100 high might be adequate, but I would appreciate any thoughts.
Martin
Martin
