wireless thermostat
28 Oct 2006
Londonderry
I'm in the market for a thermostat to be situated in the living room and I would like one that is wireless as it could turn out be rather messy with the installation of a wired one.
The distance from thermostat to boiler would be no more than 15 metres and there would be 2 walls between the thermostat and the receiver at the boiler.
Has anybody got any experience of wireless thermostats or reccomendations on a good model?
There will be no problem with it working in your property honeywell ,danfoss and drayton are all decent makes boils down to what you want to pay
As far as I'm aware my boiler is not a combi boiler, will that make any difference in the type of thermostat I choose?
No difference at all if going for basic stat if going for best practise for a normal system you can get programmable room stats that incorporate HW timings but this would be a lot dearer
Is there a difference between the basic thermostat types and the more advanced, other than cost? I wouldn't be setting up different heating zones because the boiler and plumbing isn't set up for such a system so would it benefit me in any way to go for one of the more advanced dearer types of thermostats?
Fit a Honeywell CM927. It is the easiest to use, is reliable and arguably is the best looking.
Get one that allows for different temps at different times, they are not a lot dearer, I had a standard wireless one & changed to a programmable one. Its well worth it.
