Hi there,
This is my first ever post so will appreciate comments from all the good folks here.
I have a Electric Oven (Bosch rated at around 6kW). The hob is gas.
Starting at the MCB and leaving a 30cm overhang (ready for when the sparky arrives), a 9meter length of 10mm electric cable was channeled through floorboards directly into a 45amp Cooker+Socket switch.
Question 1: Probably a daft question but is the 10mm cable fine? or should I have used 4/6mm? i.e. its not dangerous is it? 10mm cable was used as it was a spare reel I had left over.
Some suggest simply connecting the cooker directly into the 45A socket - others say install a CCU and wire the cooker into that. For now, the oven is connected directly into the socket with a generous slack for when pulling the oven out in the future.
Question 2: Is this done correctly or is it advised/law to have a CCU in-between the 45A and oven? Is it really dangerous to not have one?
Question 3:I'm no electrician but at 6kW, isn't a 45A cooker socket 'over fused' for this setup? It has a 3pin UK plug fitting on it too but I doubt that would ever be loaded more than 1kW. Any advice on this?
Question 4:What should I expect the sparky to do at the MCB? Would he use a 32A fuse dedicated to this oven? I have a new Wylex MCB with numerous new fuses I purchased recently so he can take his pick from 16A, 32A and I believe a 40+ Amp too (I do have a shower upstairs so I guess he'll be needing dedicated fuses for both the shower and cooker?)
Interestingly, I've discovered this and seeing the images, its very similar to my own setup.
