Hi, just looking to get some advice on the lighting circuit for my house. Basically ive built two new bedrooms in the attic and was thinking of the best way to wire the lighting circuit for this level of the house. I will be getting a professional in of couse. But would there be an issue with this design. If I have a panel in the ashlar space that easily accessable. On this panel there would be a wago junciton box for each room where a feed goes up into the loft space and then to each lighting swtich for each room where the lights are setup up with standard 2 plate method for led ceiling downlights. I could then connect each wagobox on this consumer panel in a radial cirucuit on this consumer panel where a feed goes off to connect to the consumer panel. Just thinking if anything goes wrong in the future or I want to add/ troubleshoot issues its all easily accessable. Can anyone see an issue with this concept in principle. Ive added a basic plan in case what im describing is not clear..
