Wiring downlights to a plug and switch
2 Feb 2016
I've got myself 6 downlights that are dimmable and i've installed them underneath wall cabinets. I want to run them from a plug socket that is easily accessible. I have a few questions
1. I am going to be using flexi cable. should i use 1.5mm2 or 1mm2?
2. Should I fuse the plug with 5A fuse or lower?
3. Is it ok to wire them in parallel?
4. Is it possible to install a 1G dimmable switch in between the plug and the actual lights so that I do not need to access the plug switch everytime? if so how will I wire this?
Many thanks
1. 0.75mm² will be adequate.
2. 3A
3. They will not work unless you do.
4. Any thing is possible. Where will the switch be?
"if so how will I wire this?". As per the instructions that come with the dimmer.
You will need one suitable for the lights and their rating (wattage).
Can you not fit a Fused Connection Unit in addition to or instead of the socket and do it properly?
Thanks for your reply, unfortunately its on a isolated wall so easiest option is to run it from a 2G socket with a plug which is getting hidden behind the base cabinet.
The dimmer switch I bought is rated at higher the wattage than all the lights combined. However the switch is a 2way 1 gang switch. It has Common, L1 and L2. I am not going to be using it as a 2 way so how do I wire it? Currently Live, Neutral and Earth and going from plug straight to the lights. How do I add the dimmer switch inline?
They often have a minimum as well.
There will be instructions with it.
Live In to Com, Live Out to L1,
Nothing in L2.
Neutrals joined together.
Earths connected to switch if metal or just connected together if plastic.
John - you really ought to have a better understanding of the basics - thinks like what a switch actually does, the difference between series and parallel, and so on.
Doing electrical work on the basis of following instructions to put-this-wire-in-that-hole without really understanding why is not a good idea.
