wiring electric cooker
22 Nov 2010
Hertfordshire
i have replaced my electric cooker , can wire into exsisting double socket,
although have noticed socket has 3 earth wires attached to one terminal.
is this ok to repeat ???. although new cooker has no insulation on earth
wire , just bare . is this safe ??.
DO NOT WIRE INTO SOCKET Any cooker requiring hard wiring as you sound to have should be wired to a purpose made cooker connection unit with a double pole isolation switch.Regarding the earth wire, it should be sleeved with g/y sleeving.Three earth wires in the socket is ok if they include a strapper to the back box.
thanks for reply . the exsisting socket has separate switch for cooker &
switch for socket . i need to cover wire with insulation then , as i thought .
The cooker should be connected to a cooker outlet plate which is supplied from the switch.
How many cables are there at the switch?
What size are they?
What is the rating of the fuse/MCB on the circuit?
What is the rating of the new cooker?
