Not an issue which can be ignored.Putting aside the issue that the supply authority should be informed of a inductive load of this size on a domestic supply
And apply for permission to use the welder as well.While I am at it I might as well put an additional socket circuit in for my MIG welder!!
How big can you go with a CU? Could I, for example, have 48 ways or is that just daft?
D
Give what you say about outbuildings and outside power I can't think of a fundamentally worse design than one giant CU for everything.
They would be called sub-mains and as you say all after the meter.I meant that each building outside would have their own supply cable and CU (although I dont know how that would be achieved since it all has to be after the meter?
When I get the pole removed I will need to put in a new meter point on the external wall, could the bus bat chamber go in here?If theres a lot of outbuildings and a lot of switchfuses you could connect them all to whats known as a Bus Bar chamber.I meant that each building outside would have their own supply cable and CU (although I dont know how that would be achieved since it all has to be after the meter?
Good grief! He's going to need to build a switch room at this rate!Bus Bar chamber.
48 ways for the house and garden?The large CU would then do the whole house and outside.
Is this your gaff?
Not just new circuits - Part P applies to any work whatsoever on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter which operate at low or extra-low voltage and are—All the new circuits will come under Part P in England and Wales
This is Part P:Today Part P has resulted in sole traders going for one or the other as scheme membership fees are too large to pay if not doing near all domestic.
