Wiring for Single socket to double
10 Dec 2009
Middlesex
When i moved in to my current propery, all but one of the upstairs rooms had flush fitted single power sockets.
The execption was one roomwhich had surface mouted double sockets like this
Im currently decorating this room and want to get rid of the plastic surface mount boxes and replace with flush mounted back boxes.
On dismantling the surface boxes i discovered that they have been piggy backed on top of single socket metal back boxes as per the attached image.
I suspect the single sockets were the original configuration as this matches the rooms that dont appear to have been modified
My question is, with the current wiring, can i safley wire up double sockets?
Many thanks iggifer
Just thought id double check before opening up the holes and getting sometwin back boxes
It does look like your earth goes to the box and then to the socket. Make sure you swap it around so that it goes to the socket and then the box
Yes, ideally that would be what one would do. However, looking at the pic I'm not sure that the incoming CPC would necessarily reach the socket (easily or at all) - in which case one might have to accept the present arrangement (arguably no worse than attempting to extend the CPC).
Kind Regards, John
I suspect that wall is timber and plasterboard (stud wall)
Check first there are no 'uprights' in the way.
A pad saw is best to cut plasterboard.
Don't forget you could use a Converta socket, though chances are it won't match any other sockets you have.
Sorry, I don't agree. It looks to me like a double pattress and a double socket mounted over a flush single box.
In fact, one can see the faceplates screws on the left and right - flush Convertas don't have these (the screws are hidden where the earth holes are).
Some double pattresses have fixing holes which line up with a standard single box.
A Converta is flush, or at least semi-flush. They are a little chunkier.
