In my house as there are in most, the loop system, I would like to replace the ceiling rose with a flush circular light but it only has a terminal block to only L N E. What do I do with the 4 red cables in the middle terminal?
those wires in the middle terminal...what purpose do they serve?
If you are talking about the reds in the loop connection/terminal.those wires in the middle terminal...what purpose do they serve?
Sounds like you have it, what you must remember that when twin and earth is used. the core colours for the switch conductors are often that of live & neutral (black and red) the black cable is not a neutral but a switch wire, which is a live and should be sleeved, marked or flagged up to identify it as so.so, to clarify when i put my new fitting on, neutral wires, earth wire and switch live go into light fitting. one of those reds in the loop will be from the switch cable so for all to work the reds all into one terminal block or wago connector? is that right?
Spark123 was the original author of the Wiki article, but I have a nagging feeling that I originally posted it the sticky before we had the Wiki.The reason for not using insulation tape is that it is not really a suitable material to use, don't get me wrong it is used and who ever was the authur of the link I suppplied, may have or still does use it.
But AFAIR it has always had the instruction not to use tape. The thing is it's a good diagrammatic explanation of how to replace a loop-in rose with a light fitting with only 3 terminals - it would be a shame not to use it because of the tape issue.
Yep, it was from the stickySpark123 was the original author of the Wiki article, but I have a nagging feeling that I originally posted it the sticky before we had the Wiki.
