I recently moved into a new house (new to me anyway!!) and am looking into adding some more sockets as they are few and far between as it is.
This is fine apart from a couple of things I have come across this weekend.
First of all I should say that every socket in the house is fed from a single 30 amp fuse in the CU and is run in 2.5mm T&E.
Problem number 1 is that the circuit appears to be a radial because the double socket in the shed has only one cable running to it and so has no return to the circuit. I also know it is not a spur.
Now this too is fine but I was under the impression that radial circuits should be run in 4mm cable with a 20 amp fuse. Am I correct in assuming this??
Problem number 2 is that upstairs there are 2 single sockets that have 3 cables coming into them. One of them is in bed2 which also has a single socket with only 1 cable so i assume that is spurred off. The other one in the landing however doesnt appear to be feeding anything. I have had every socket off the wall and no other socket (exc shed) has only one cable going into it so I am puzzled as to what the 3rd cable feeds (if anything).
I have done a quick sketch to show a little better (i hope!!!) what I mean.
View media item 1786
