I've currently got 4 no. downlights in my bathroom which return to a single rocker type switch in the hallway, all of which is connected through a typical ceiling rose in the loft above, however it is currently a bit of a state - the incoming cable from the previous rose, and outgoing to the next, seem fine, but the feeds to the lights don't make sense. From the rose is a cable that feeds light 1 and 2 in a radial arrangement, and there is another two cables feeding lights 3 and 4 in a ring arrangement, e.g. there is a cable between the rose and 3, and the rose and 4, and a further cable between 3 and 4.
The lighting currently works, however I am (with some help from my father who is an electrician) in the process of rewiring the house anyway as the cabling is old and generally a mess, and will be tidying up the bathroom lighting as part of this.
My question is - what is the best way to wire all of the lights back to the switch?
I understand the fundamentals of wiring a ceiling rose to a switch, but as the cabling from the rose isn't via a bit of flex that would go to a pendant type light, is there a better way to do it?
I am currently thinking of using a four terminal junction box with the following:
Terminal 1 - IN live, OUT live, SWITCH live
Terminal 2 - IN neutral, OUT neutral, LIGHT neutral
Terminal 3 - IN earth, OUT earth, LIGHT earth, SWITCH earth
Terminal 4 - SWITCH neutral, LIGHT live
I'd then wire the 4 lights as a radial from the junction box.
Which I believe effectively replicates what is going on in a ceiling rose. I could use another rose, but it doesn't seem particularly neat as there won't be any flex coming out of it.
Preempting the "if you don't know how to do it, you shouldn't be doing it" comments, of course I will get it checked over my dad before I go turning the circuit back on.
