Hi
I need to connect an oven and hob, I've looked at the regs and calculations etc and can't see anything I'm missing or wrong, but if someone's kind enough could I get a second opinion please?
Oven is 5.9Kw / 25A
Hob is 7.4Kw / 32A
Cable is 6mm T&E (clipped direct) which should allow max of 47A. Length of cable from CU about 10M.
Doing a diversity calculation says 24.3A diversity load.
The same cable will be feeding the oven and hob. Wall space is very limited, ideally I'd like a double-switched 45A DP switch but I can't find one (i.e. one switch for the oven, and one for the hob) - anyone know if these are available?? Failing that, is it OK to run both appliances from a single 45A DP wall switch then run down to a dual appliance outlet plate or must each appliance have it's own switch?
Any ideas, criticisms, or help would be really appreciated thanks!!
Dave
Oven is 5.9Kw / 25A
Hob is 7.4Kw / 32A
Dave
