wiring plinth
1 Jul 2011
Lanarkshire
Got a 12v transformer plinth light jobby from bigshed. Its a molded plug. And ive under cabinet lights that run of a fsu ( not very pretty plonked on tile run). I would like it so I could switch theses on together from a 2 nd gang on light switch. is this doable of is fsu only way ( not pretty )
If the feed to the lighting is via a socket circuit or/and if the manufacturer's instructions recommend that the circuit is down fused for the transformers? Then you will require a FCU to do this, before any switching arrangements.
The circuit at moment is 240 from fsu. For undee cabinet lights ( gonna change then to led) and the led plinth lights. Its just junction box and a 12v tranny. Ive tested it plugged into mains. I will try find ampage of them and if I get cabinet lights that are about 3a then maby can run both ( if plintg lights are 3a) from the lighting circuit . Under cab lights should be Around 3 in total
Red underlines ?, just want to run 3 led under cabinet lights and printh lights from a lightswitch. But know if has to be fused down using fsu before going to lightswitch. The cabinet lights I've not bought yet just the 12v led plinth lights. Old set up was 3 tube lights going to fsu
Red underlines ?
These:
Lol didnt come up on mine. Obviously some spelling mistakes and words that are not in the database lol. Didnt check before posted as doing it on small screen and at work without getting caught lol
