Hi looking for a bit more advice. We checked our cosumer unit and its a MEMERA 21 (Tested to BS5486
t13) loading 100Amps max. There is one blanked space available for fitting another MCB.
The kitchen sockets are part of a ring main that includes the bedrooms in the property (bungalow). The existing oven is connected directly to the consumer unit via 45 amp cable and has its own connection switch in the kitchen.
We are installing the following appliances:
Induction Hob (total connected load 7200 watts) - this will be situated where the existing oven is so we were planning to connect it to the existing 45amp cable and switch unit.
Oven (total connected load 3680 watts) - this is a new installation so no cabling exists.
Steam Oven (total connected load 1900 watts) - again this is a new installation so no cabling exists.
Both these appliances will be situated in units next to each other and are approx 3m from the consumer unit.
What do I need to do to connect these new appliances to the consumer unit and also is what we're planning to do with the induction hob acceptable?
If RCDs are required, where should they be fitted - is it to each appliance and do we need to fit RCDs to the socket ring?
