Wobbly fence post
16 May 2014
Aberdeenshire
Hi
Can anyone suggest how to fix my wobbly fence post. Its only been in 18 months but because its against my neighbours path I couldnt get a full circle dug for putting post in. I had to just dig a half circle but now its wobbling and leaning towards his garden. Would it be worth digging the hole a bigger diameter and putting more cement in once its straight?
Without taking out and redoing I think whatever else you do will just delay the inevitable. While it is still quite wet now would be a good time to dig before summer when the ground will be a nightmare.
How tall is the post?
How deep did you dig the hole? (Needs to be about a third of the finished height deep. e.g 6' above ground requires at least 2' underground)
You could dig it out, make the hole the required depth and then hammer in a metpost to the bottom of the hole and clamp your post into this.
If you dig the hole deep enough can you dig under your neighbours path a bit to get a full circle of concrete around yours? It may also give his path a bit of extra support.
i was thinking padding out to the path edge and back filling lower down on the post other surface but that may not be a good idea iff the fence moves too much and unsettles the slabs ??
