Hi all,
I've got a couple of questions regarding the instalation of a log burner with a back boiler.
I've looked at a couple of systems to link it into my existing centeral heating but if you consider the additional costs of the installation, it will take years to pay back so i might as well keep with just a gas boiler. Hence the system i have come up with needs only a bit of additional pipe work and a couple of new rads in rooms which need addational radiator capacity anyway.
View media item 40663
The plan is to run a completely seperate system along side the exsiting gas boiler. I've checked the regs regarding the copper float and overflow for the F&E tank.
Can anyone offer any advise on my system design, all comments welcome, good or bad!
i've also got a couple of questions.
1) does the expansion pipe have to be 22mm and can the feed pipe be 15mm?
2) is 60°C ok for the stat controlling the pump.
3) are the 2 rads located on the gravity loop (bedroom and bathroom)2.1Kw enough capacity for the 5Kw back boiler of will i need additional rads on the gravity loop, to prevent the system from over heating if the pump fails due to a power cut?
4)will the 2 additional rads mounted downstairs off of the gravity loop still get hot if the pump fails?
5) could i run the pump off of a large car battery via and inverter, which is keeped trickle charged from the main, but will provide a couple of hours run time in the event of a power failure to allow the fire to die down.
thanks in advance as i'm new to this older style of gravity centeral heating design.
