Wood hardener or wood preservative?
25 Feb 2014
Kent
Hi
I have had an issue with rotten wooden window frame. I have scraped out the rotten wood as far back until it no longer scrapes off. The wood still seems a little damp and soft but not soft enough to Scrape any more out and it looks healthy. What is the best solution to use when it comes to treatment? I have been told to use wood hardener, but I have also seen some wood preservatives which say they soke into the wood to kill fungus. I just want to be 100% sure that any remaining fungus is killed.
best solution cutout all soft wood and splice in new wood and glue into place without any filler
in the real world remove all soft material or as much as practical [at least say 90%]
use hardner [this does no more than hairspray holding loosish material together and ads zero strength] use filler sparingly with all exposed edges replacement timber and filler as an infill
Thanks big-all
Is there any particular glue that would be best used in this situation? Or will standard wood glue do the trick?
You need to dry the timber and deal with the cause of any dampness first
Hi woody
The source of the damp was failed sealant on the bathroom tiles so it will be fixed once the tiles are replaced.
It is already feeling dryer this morning which is good. Is there anything I can do to aid the drying process? Or am I better to just leave it?
Warmth and air flow is best for drying. But you do need to be sure not the trap any moisture in the timber with the work and then the finished coatings
