woodburner gap
27 Feb 2013
I am installing a woodburner which i intend to get Hetas signed off but I have one question I am unsure of.
The woodburner is slightly smaller than the opening so is sat in front of the fireplace. It has a teepiece and rear outlet. The back of the stove runs parallel to the wall and there is a 70mm from the corners of the stove and the corners of the wall alll the around. The walls are brick and plaster so non combustable. Is this gap sufficient?? I know most people generally suggest 150mm but this is between to large surfaces and not just the corners.
Any thoughts gratefully received.
Cheers
