Worcester 240 RSF no hw, good CH
6 Mar 2005
Am only getting hot water when hot tap is fully open. Understand that it is most probably the diverter valve. Are they straight forward to replace? Also found a GIANNONI valve on www.ezyparts.co.uk for £36, are these any good good or should i fit a genuine part?
It's probably the diaphragm inside the diverter.
Getting the part is easier than fitting it!
you probably also need the slip couplings for this(about nine quid as they normally leak when you change the valve or overhaul with new diaphragms :wink:
