Worcester 24i Junior Flow Turbine Sensor Replacement
17 Apr 2011
Cheshire
Hi Guys,
Following all your great advice on previous posts, I believe I need to replace (or at least clean) the flow turbine/sensor on my Worcester Bosch 24i Junior combi boiler. I can remove the panels to access it, and I am confident enough to remove it myself for inspection, but is there anything else I need to be aware of? Do I need to turn off the gas supply, if so where? Do I need to turn off the DHW feed or anything like that? Presumably I need to switch it off at the mains too? Do I need to apply some sort of paste when I put it back, as suggested in the manual? Once I have the sensor in my hand how do I check it or clean it? Any advice very gratefuly received please, my cousin is visiting with her baby and we have only intermittent hot water!
it would be funny if he/she took you at your word and just went for it. :confused:
