Hi Guys,
Following all your great advice on previous posts, I believe I need to replace (or at least clean) the flow turbine/sensor on my Worcester Bosch 24i Junior combi boiler. I can remove the panels to access it, and I am confident enough to remove it myself for inspection, but is there anything else I need to be aware of? Do I need to turn off the gas supply, if so where? Do I need to turn off the DHW feed or anything like that? Presumably I need to switch it off at the mains too? Do I need to apply some sort of paste when I put it back, as suggested in the manual? Once I have the sensor in my hand how do I check it or clean it? Any advice very gratefuly received please, my cousin is visiting with her baby and we have only intermittent hot water!
