Hello, I have a problem with my boiler. A couple of days ago the heating stopped working,when i went to see what the problem is, one of the valves was leaking a little bit, so I bled one of the radiators(I dunno why I did that,but it worked). Unfortunately the next day, the boiler stopped working,and the pressure now is 0 bar. Whenever I turn the hot water on, I hear the spark, but after 2-3 attempts to ignite, it stops and the red light flashes. Could you tell me how I can fill the boiler again?so that the water pressure is ok? Somebody told me I need a key an that there is a slot at the bottom of it. I'll attach 2 pictures(actually 3) so that you guys can get an idea.
if you look underneath the boiler at the front you may see a black plastic manifold with a white plastic nut on the left hand side. Be best if you can look uderneath and let us know if that is there.
