Worcester 28i RSF Hot water temperature fluctuation problem
Cheers for that.
Its a bit weird.
It was only affecting the hot water, not the central heating.
Now its affecting both.
sometimes this happens as the fan will run at different speeds for hot water and CH, now they both don't work it probably just filled with more water causing a restriction on the switch to its unable to pull the switch open, you don't need a new switch you can get the water out easy but you will require a gas engineer out to replace your auto air vent as its above the burner , and if not replaced your problem will reoccur.
let us know how you get on.
cheers
Another update.
Fitted new air pressure switch. Same problem.
Tried gently sucking on the -ve tub going to the air pressure switch. Switch clicks and boiler ignites.
I then traced it to the Flue Flow Sensor (ie venturi) in the fan assembly. Removed this and cleaned it.
Eureka.
I will order a new one and fit it but currently the system is running A ok.
Thanks for all your help.
We dont advise DIYers to open the combustion chamber or replace combustion related parts.
Understood.
I know my limits.
I am a field service engineer, just not with gas boilers (semiconductor manufacturing equipment.)
Hi there, sorry to bump an old thread but my boiler (same make and model) is experiencing exactly the same problems as those described here.
May I enquire as to what the eventual problem and solution was?
Thank you
Janus, there can be many different causes of your problem.
If it happened to be the same cause then we still don't give DIY gas advice.
Yeah I'm leaving that stuff well alone. I'm getting a guy around next month to look at it, it would be nice to know before then what the problem is.
Either way I'll post my experiance once it's fixed for other people's reference.
Thanks.
I had this problem with a 24i, the gas valve/modulating valve was only working at 50% capacity, new valve from ebay, trusted gas engineer with kit to change and test all all right since.
