sometimes this happens as the fan will run at different speeds for hot water and CH, now they both don't work it probably just filled with more water causing a restriction on the switch to its unable to pull the switch open, you don't need a new switch you can get the water out easy but you will require a gas engineer out to replace your auto air vent as its above the burner , and if not replaced your problem will reoccur.
I had this problem with a 24i, the gas valve/modulating valve was only working at 50% capacity, new valve from ebay, trusted gas engineer with kit to change and test all all right since.
