Apart from the 24V you said that!plug-in 24v relay switch: Manufacturers part number 8716146118
Where does it go? Someone will need to be able to look inside a boiler and find it from what you say..
ChrisR said:SOunds a bit like the switches on the end of the diverter valve are sticking. See if water has got to them.
WHich model, by the way?
If you need a secondary (domestic hw) heat exchanger for it I have one, by the way, which I doubt I'll ever install!
HelloHarrogateGas said:A common fault on these is the pump over-run stat........at a set temp the switching switches over on the stat fo the pump over-run .....if this fails your pump might be stoping and thus overheating. Ive changed a few of these for this fault over the years.
