First of all, I am not going to try to fix this myself unless it is very simple, but I would like to be able to talk sense to a heating engineer when I can get hold of one.
I had a plumber out to fix my Worcester Heatslave Combi boiler before Christmas. He seemed to have done it. The boiler ran for a little over 24 hours then went again.
He reported back to the person who was here to meet him that the motor and fan were stuck, that he had freed them up as best he could, but that they might need replacing at some stage.
Of course I have contacted him, but he is signalling lack of interest. He is under impression it is the same problem as before.
However, before he came out the boiler was totally conked out. This time the burner fires and I get a few seconds worth of action before I get the error code signalling burner lockout.
I have checked the oil feed from the tank and there is no air or blockage in the line in the feed outside the boiler. I have undone the bleed screw on the burner and got a trickle of oil, so it looks to me as if there is no air in that line.
I have bled all the radiators and found air in one of the them which, it seems, caused pressure to drop. However, even with the radiators bled and the pressure holding steady at around 1.5 bar I am still getting burner lockout.
So my question is: if the boiler is running for a few seconds before cutting out with burner lockout is this likely to be the same issue with the motor and fan, or something else? And if something else, any ideas what it might be?
What I am trying to do is avoid repeated visits which will quickly start to add up to a significant chunk of the cost of a new boiler.
Thanks in advance for any advice.
